Originally posted by S4-Sleden
1000 + bhp s2
Don't know the full spec but I bet it ain't too far off the magic thousand!!!
OK, It's street legal and how much fun can a man have in 9 seconds!!!
Ok, so it's running a 508ci Chevy motor so it doesn't really count, but if you had an S2 you wouldn't want to drop a Chevy block in it would ya!Comment
krb's urq: the rear end are some ford 9" eurpeean part,and he have blown the rear end 3 times,engine and tranny have been about 50cm back in the enginebay.Comment
It's not an S2, started life as a 1989 Coupe 2.2E (FWD). It's been converted to RWD, running a big block American V8, and it HAS cracked the 1000 PS mark!Originally posted by S4-SledenDoesnt look much like a an S2 quattro.............does it even have the 20v turbo inline 5 engine ???
Look at the headlights and the grille
I've seen it go down the Pod, and it is quick, and the noise...
Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eatComment
You could have 1000hp if you put turbos on a 4.2. Chasing 1000hp in a 5 cylinder is a not a good use of anybody's time =p4.2 ABZ V8 1993 B4 Quattro
http://www.ubernugen.comComment
I have a friend who is putting turbos on 4.2 S4 engine for the past 3 years , not a really good idea at all. Still haven't finished his project ...Originally posted by ubernugen.comYou could have 1000hp if you put turbos on a 4.2. Chasing 1000hp in a 5 cylinder is a not a good use of anybody's time =p
. All becouse there aren't much info on the subject.
And as I see it , it's easier to get 1000HP from 5pot then put turbos on that 4.2Vadim.
New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !Comment
Ah, but not if your friend goes the RS6 route!
Good luck to him, it should be an awesome engine when completed.
