Need some advice/help
  • AbsS2
    • 285
    Last couple of days ive been getting the engine oil warning light come on. The engine oil level is always ok. Seems to happen on fast acceleration, moving on an incline or when taking sharp bends. It will come on flash 3 times then disappear. any ideas? It has been recently been serviced but i topped up the engine oil with 'possibly' a different make of engine oil. could this cause the warning light to come on?
    Coupe
  • BRY
    • 3755
    What does your oil pressure gauge display when this happens?
    • AbsS2
      • 285
      didnt check gauge at the precise moment, but afterwards i glanced at it, it was 1.9 - 2.0 bar.
      The first time this happened was when i tried to overtake someone, was in 2nd WOT. I backed off right away
      Coupe
      • WabTheKing
        • May 2004
        • 2567
        mine does the same - loads of oil pressure = fooked oil level switch think its the single wire senser next to the little barrel senser with two pins on in the side of the block under the water manifold
        HTH
        will
        • AbsS2
          • 285
          i had my aux rad and water pump replaced recently, could it be possible this sensor is nearby and hasnt been plugged back in properly?
          Coupe
          • WabTheKing
            • May 2004
            • 2567
            no cause if it was unpluged it would be on all the time, i thought it was a dodgy connection but checked em and all was well so thinking the switch is on its way out, havent bothered changing mine because engines coming out in a couple of weeks so ill do it then to save a bit of skin on the back s of my hands!
            • pixsaudisex2
              • Sep 2004
              • 3110
              oil light
              i had this same thing happen and it turned out id got the wrong oil filter of a parts supplier after asking for s2.
              i got a thingy one and when i changed it back to the propa job the light never came on again... touch wood!!!!!!!!!!!!!!!
              also mixing oil can cause problems you know not makes but types of oils semi full etc can case a froth in the oil and the oil pump can not pick this up and send it around the engine which can cause huge problems....
              • AbsS2
                • 285
                slight update. it is now dumpin oil on the street. leave it over night and on the driver side under the bonnet/bumper it leaves a nice bit of oil . Ive had into a garage and they ran it for an hour and it only dropped a penny size oil drop. the garage say they will have to strip it (left bank they reckon)and clean it before they can see but 'they dont get involved' in all that arrrrrggggggghhhhhh. not sure what to do? keep topping it up?
                Coupe
                • kwlw
                  • Sep 2004
                  • 1025
                  • Country: Lithuania
                  I have seen audi oil pressure switches (you can call that "sensor") leaking under pressure or higher rpm. They were leaking through contact with tiny, hard to see stream of oil. I've got loss of oil pressure due to that, and oil on the ground . Solution - replace both switches (on S2 you have only one right, another is not switch, but sensor, and leaks rarely ?). It cost me 10$ . Worth to try IMHO.
                  Sau
