as some of you are aware im intending on putting a 4.2 40v v8 lump in my 90cq
which may also (pennies permitting) have an eaton m90 supercharger
now the problem i have which i cant get my head round at the moment is what to do as regards ecu's
do i use a standard ecu and get it moddifed to read forced induction, and have the headache of having to mess about having it decoded if i dont have one with the key fob
or buy an ecu from someone like 034efi, emerald, dta etc? which would come with a base map to get the engine running then get it remapped to suit on a rolling road
also my rev counter is for a 5 cylinder, i have spoken to dta and they can program the out put of the ecu to read the right rpm on a v6 rev counter so that wouldnt be a problem, where as if i used a motronic ecu this may not be as simple unless of course i fit the clocks out of an A8
cheers
will
cheers
will
