new ecu or modify old one?
  • WabTheKing
    • May 2004
    • 2567
    as some of you are aware im intending on putting a 4.2 40v v8 lump in my 90cq
    which may also (pennies permitting) have an eaton m90 supercharger
    now the problem i have which i cant get my head round at the moment is what to do as regards ecu's
    do i use a standard ecu and get it moddifed to read forced induction, and have the headache of having to mess about having it decoded if i dont have one with the key fob
    or buy an ecu from someone like 034efi, emerald, dta etc? which would come with a base map to get the engine running then get it remapped to suit on a rolling road
    also my rev counter is for a 5 cylinder, i have spoken to dta and they can program the out put of the ecu to read the right rpm on a v6 rev counter so that wouldnt be a problem, where as if i used a motronic ecu this may not be as simple unless of course i fit the clocks out of an A8
    cheers
    will
  • quattronutter
    • Jan 2005
    • 690
    you will also have to look at changing the injectors and a few other bits if you plan on supercharging it,i did look into this a year or two back,i bought an a8 4.2 quattro sport instead,the 4.2 would be awesome with a supercharger,plenty quick enough as it is though!!
    • volcano rs
      • Jun 2005
      • 2265
      go with dta you can do lots with it .i was going to do that and should have
      • Corey
        Banned
        • Sep 2003
        • 2793
        034 will cover everything you would ever need. The also do a plug nd play harness for the V8
        Corey
        01636 822288
        • Fat Audi 80
          • 10547
          I would ditch the supercharger and keep it all standard. I would use all the clocks, keys, ignition ECU etc and plug and play.....
          A simplified view I know, but that is the way I would look at it. Then once it is up and running I would *think* about supercharging etc....
          Sounds like fun!
          Good luck
          Cheers,
          Steve
          The Perfectionist
            personally i'd go with the emerarld ecu remap. Jolly good chaps and the results they've had on TVR's speaks for itself.
