What triggers overboost?
  • AndyP
    • 6049
    The car has a new WGFV and the overboost has worked since that was fitted, it's only stopped working recently, I'll check the throttle settings with VAG-COM to see if they match the values quoted by Paul.
    Andy
    • slow2
      • Apr 2004
      • 238
      I followed the checks in this thread,
      here are my results:
      before adjustment
      pins kohm
      1-2 700
      2-3 2347
      1-3 2317
      after adjustment
      pins kohm
      1-2 1280
      2-3 2638
      1-3 2489
      so after me seeing these reading and reading the above thread i decided to open my altitude sensor and adjust the metalic strip inside until i got a steady reading of 1280kohm between pins 1-2.
      Jumped into car convinced my boost troubles would be over
      drove the car round local streets until warm then headed for private track for some tests, i stil can only get a maximun 1.2 bar boost in all 6 gears on a homefried
      car
      the boost battle continues
      Dez
      Never did overtime until i purchased........s2
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        Originally posted by Jamo
        No it's defo load related, S2entral.net test for it is to floor it up a hill in 4th gear and you should see 1.1 boost
        I too only seem to have overboost available. It does seem to me that it is based on the speed of throttle opening as well as WOT, but I have a major problem....I live in East Anglia....THERE ARE NO HILLS
        The closest thing I have within probably 30 miles is a fly over, but its damn hard to hit full boost up a flyover in 4th and still make it around the roundabout in one piece
        Is there any way of testing this more scientifically, for flat road use? For instance, is it possible to hook up VAGCOM whilst driving and see a read out that says overboost is being used?
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • WabTheKing
          • May 2004
          • 2567
          Cheers n
          Si
          left foot braking
          • HPmuirt
            S2Forum April Fool
            • Apr 2005
            • 3014
            #20
            Originally posted by WabTheKing
            left foot braking
            I'll send you the bill for the Textars
            Actually, it is a good idea, I'll see what happens tonight
            Cheers n
            Si
