S2 Coupe Weight
  • caterpillar
    • 2480
    #31
    every 200kg loss= ca 40hp +at the engine..... my 32bQuantum ca 1200kg and 2555ccm
    • nigelm
      • 150
      Alternative Viewpoint
      Seems boring but I'll be relying on my Procon -Ten if I crash. Funnily enough I'll then also be glad of every extra kilo to dissipate the impact forces.
      Still - it'll never happen now will it?
      nigelm
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        Conversely, every extra kilo will actually increase the forces in the event of an accident - but (a) the forces will transfer into whatever you hit (depending on how soft or hard the object is, this may be a good or a bad thing), and (b) the ProConTen will tension the belts and yank the steering wheel away from your head! Of course, this all assumes a head-on impact, anything else and ProConTen won't be much use anyway...
        __MDC__
        Martin Cutting
        • T2Andy
          • 1903
          im sure fitting the 18 S8 wheel has blunted the performance as well as the s8 disks they are so heavy over standard.
          • mcandmar
            • Apr 2004
            • 5118
            I wont know until i try and fit it I was told the transmission tunnel is smaller on the CQ so the cable guides for the Procon Ten foul on parts of the gearbox. Its extra weight so i want to ditch it anyway.
            Originally posted by Mikes2
            6 speed ABY cars up until 1995 MY had ProCon Ten so could you not use it as fitted.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • hiltoa
              • 1060
              • Home: United Nations Current: England
              #36
              I may be getting the wrong end of the stick, but don't we generally like our audi's specifically because they're not superlight tin cans?
              If you want to lose weight, buy rice...
              Nothing feels fast for long...
              2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
              • Chris5044
                • Feb 2005
                • 1663
                dont be silly
                  • Dec 2003
                  • 2317
                  Well, you could look at this another way Hiltoa - if you started out with rice, it would be difficult to get any more weight off the car, whereas we have lots to play with!
                  I'm just teasing. Yes I like the solidity of my Audi, but there are many parts which really don't need to be as heavy as they are, and some don't need to be there at all. Other parts are considered a good weight sacrifice, like better brakes or the extra shell stiffness afforded by heavier construction.
                  But bear in mind that every extra bit of weight is hurting performance and asking more from the durability of mechanical parts (engine, gearbox, drivetrain). Losing weight where it really isn't needed is not a bad thing, is it?
                  __MDC__
                  Martin Cutting
                  • mcandmar
                    • Apr 2004
                    • 5118
                    I went from a 740kg 160hp Honda to my 1400kg 170hp CQ, theres a massive difference between the two. Night and Day, Truck vs go-kart. You just wouldnt belive how quickly you can change direction with 740kg. An S2 on a diet would be mind blowing
                    • 1975DCS
                      • Sep 2006
                      • 258
                      Originally posted by mcandmar
                      A US spec CQ20v weights 1440, dump the AC, elecy seats, and safety bumpers it must be a little under 1400.
                      My 3B weights 1444 kg according to the roadtax forms. But here I read 1420 kg, mine is without airbags, but with sunroof and electric windows... Is this 1420 kg? Still heavy...
                      • volcano rs
                        • Jun 2005
                        • 2265
                        if they wearn't that well built we wouldn't be here talking about them
                        • WabTheKing
                          • May 2004
                          • 2567
                          i have removed
                          procon 10
                          abs
                          bomb brake system
                          all plastic shrouds i dont need
                          all carpets
                          all interior pannels
                          front seats replaced with cobra monacos
                          fibre glass front bumper
                          aluminium engine, (need to weigh)
                          wonder how much weight i have lost?
                            You'll need a lifetime supply of ear plugs Wab thats going to be a nosiey ride!
                            • Chris5044
                              • Feb 2005
                              • 1663
                              Hello again dudes.. been away for a while ... so did you find an answer Wab? how much it weighs? and also does anyone know the lightest s2 around? ...
                              Be good to get it below a tonne (carbon doors?)
                              • Aurélien
                                • 48
                                • Country: France
                                #45
                                wow...
                                1100 kg , how to ?
