RS2- how do i remove injectors?
  • S-Express
    • Nov 2006
    • 1133
    Originally posted by s2driveruk
    In the post tonight Thats fantastic!
    David
    Anything for the good of the forum!
      Originally posted by S-Express
      Well i've just ordered 110 o rings at a cost of £20.
      As I'm such a nice bloke I'll give the first 10 people to send me an sae to my work address 10 lovely o rings foc - can't say fairer than that.
      Send SAE to:
      Vannplastic Limited
      Unit 6/7, Brymau 4 Trading estate
      River Lane
      Saltney
      Chester
      CH4 8RF
      Brilliant - Marked for whose attention ?
      • S-Express
        • Nov 2006
        • 1133
        Alex - or you can just put "the only one who does any work there"
        • s2driveruk
          • 12696
          oops, only just read this, i sent mine as listed with just an envelope with my return details on.....hopefully it will arrive ok with you
          1992 3b S2 Coupe
          • S-Express
            • Nov 2006
            • 1133
            #20
            It will, there's not many of us here.....
            • Audi Parts Guru
              • 1317
              #21
              Thanks Alex, envelope is in the post tonight
              • Big_kev
                • Dec 2006
                • 159
                sliding along to you in the snail mail as we speak. If i am outside the first 10 then let me know and i shall square you away with paypal or whatever.
                Thanks again
                Kevin
                PS do injectors have a life expectancy and is it worth having 200,000 mile injectors cleaned or just replaced.
                  #23
                  Get 'em cleaned & balanced by your local (or remote) friendly neighbourhood Bosch/ASNU agent. And yes new O-rings are a must when you refit them really.
                  Paul
                  • Audi Parts Guru
                    • 1317
                    #24
                    Kevin,
                    Injectors don't have a life expectancy as such, however it is definitely a good idea to get them professionally cleaned by someone who uses the Asnu machine as this is the only injector machine that has approval by Bosch in Germany.
                    A proper injector service will involve flow testing the injectors to measure fuel flow rates, spray pattern analysis, leak testing, resistance testing etc. Ther injectors will then be cleaned in an ultrasonic bath for about 20 minutes and then flow tested again.
                    Assuming that the injectors have passed the tests after cleaning then new O rings should be fitted along with new filter baskets, spacers and pintle caps. The injectors are now ready to be fitted back in to the car.
                    • Big_kev
                      • Dec 2006
                      • 159
                      What kind of cost is involved in this kind of cleaning etc
                      • Audi Parts Guru
                        • 1317
                        #26
                        Anything between £15 and £25 per injector, but do your homework first as there are some injector service centres around that are shall we say, not very professional
                        • S-Express
                          • Nov 2006
                          • 1133
                          #27
                          I'd just like to point out.
                          Once they're gone, they're gone.
                          I won't be getting any more - you can however buy direct via internet will cost you about £5 inc p+p for 10.
                          Its costing me £20 to get 110, and 90 are to be given foc in lumps of 10 to the first 9 who mail me with an sae. If you're number 10 or 11 or whatever - I'm sorry but thats just the luck of the draw - you will have wasted a stamp which I will no doubt steam off and re-use
                          The linky (if you wanna orxder direct) is:
                          cheers boys
                          • Knight Rider S4
                            • 3541
                            Put me down for 10 as well SAE on its way
                            Steve
                            93 S2 Avant Parting
                            91 URQ RR
                            02 A4 tdi Avant
                            • S-Express
                              • Nov 2006
                              • 1133
                              #29
                              Steve
                              I'm just gonna go by the first 9xsae's I recieve
