The effect of altering cam timing varies depending on the rest of the engine spec. With regards to stroke, desired rpm band, turbo and headflow.
My original 7A combo on paper redlined at around 7500rpm which it did at 1.7Bar of boost. Once I turned the boost upto 2 bar this peak power came down to around 6900rpm as the hotside of the turbo (0.63) was too small to support the extra exhaust gasses. But same cam profile.
Very smooth power delivery, real nice on the track but missing midrange grunt for the road. So after numerous calculations on an engine simulator I advanced the intake cam only (left the exhaust alone) by 7 degrees. Result in difference in power delivery is attached.
Now by advancing the intake cam the redline changed from 7500rpm to 6800rpm on 1.7bar of boost but on 2bar it made no difference to the original non advanced intake profile as you can see from the attached.
I've sorted the voltage out on the fuel pump to ensure no more lean spikes, fitted a .82 housing and a vernier on the cambelt and once Mihnea is in town I will have a little play on the dyno. My suspicions are the whole setup will need to be retarded by a couple of degrees to make more low, mid and top end. As by advancing and retarding the whole cam combo doesn't necessarily shift the same shape power curve on a turbo car the way it does on an NA like I have found in the past.
