7A Exhaust Cam
This is a sticky topic.
  • Look at the Dyno at Picture 46.......
    http://www.s2forum.com/forum/showthr...t=22861&page=4
    Thomas
    • Quick question then.
      This is a dyno with my car. Engine spec is as follows.
      Stock AAN block.
      Stock AAN pistons.
      H rods.
      ARP bolts throughout.
      New bearings and piston rings and so on.
      Stock head with stock running gear and cam.
      PPF manifold.
      Garret turbo charger.
      Kompressor: GT40 0.58 A/R, 48 trim
      Turbine: GT37 0.99 A/R, 73 trim
      1600cc injectors.
      Stock s2 wastegate with 1 bar spring.
      Dyno is made at 1.9 bars of boost. After that the backpressure starts building up.
      I like the powerband so that i dont want to hurt that much but maybe some more power and less lag? Would 7A cams be appropriate for this kind of power or is it just a waste?
      Graph
      Numbers
      • Not bad Mannen
        Whats the AR on this Turbo ? Check my results with 7A Cams
        We tried both with Racecams and 7A's must say im impressed , we got 1,2 kg's of boost at the same Rpm's with 7A's
        Its not a bad suggestion bro.
        FEEL THE DIFFERENCE
        -Audi S2 " The Sleeper" 704hp 880nm
        -Audi S2 ""Audi S2 Racetrack
        • Originally posted by chipsenter View Post
          Not bad Mannen
          Ahh sweet. Did you choose racecams or 7a in the end?
          Theese 7a cams seems more and more interesting.
          • 7A's Man
            FEEL THE DIFFERENCE
              7A's Man
              Sweeeet will have to get me a couple of thoose then Cheers
              • chipsenter, your brother told me about the race-cams...
                i will keep my 7a´s for sure
                did you change to both 7a or only exhaust cam and some other inlet?
                • Originally posted by lind4hl View Post
                  thought the general opinion on running both 7a cams is it makes the car even more rubbish on fuel
                  • In an earlier post it was mentioned that using a 7A cam with a map made for AAN cam would make the engine run a bit lean.
                    I have a map made for 7A ex cam, but running with the stock AAN. My AFR is down at 10,4 which is a bit rich. So this seem to be correct.
                    Engine runs BTW very nice.
                    This is with a GT3071, .63 ar. RS2 ex mani, 3" DP and BN pipes exhaust. 034 chip set. Max boost 1,8 bar.
                    I will install a 7A ex. cam shortly, but will take some G-tech runs so we can compare.
                    • Hi rwilthil, your setup is very interesting. Do you have a project thread somewhere so we can share experiences?
                      • After reading several pages here, about the 7a cams, i`m a little suprised no one has experimented in timing both cams a little..
                        I have seen one guy posted that he had changed the cam timing for both (only outside adj. wheel), without any gains, but i cant seem to find anyone that has tampered with BOTH cam timings separately yet..
                        If anyone can point out any writings/dyno`s on someone`s tweaking the 7a cam timing separately, i would be very interested in this.
                        I`m going to try a little myself, with G-tech, before i hit the dyno.. And i`m not sure if i will go for ADU or 7a cams yet, allthough 7a seems to be prefered by most people.
                        94` RS2 Sedan
                        • I have my Original Camshafts here on the table now.
                          And im asking myself (and you ) how to disassemble the Chain Gear from the cam ???
                          • Originally posted by Ola View Post
                            They have, Audi_CQ and Repo have posted about changing the timing.
                            Audi_CQ has posted the timing changes on the forum
                            • Originally posted by rash View Post
                              Use a heater to expand the chain gear wheel (and be sure not to heat the cam!) and use a rubberhammer hammer it slowly off, working in circles untill it is off. Use extreme caution when doing this
                              Anders - S2 Avant Clubsport - 8pots or die!
                              • Originally posted by AndersS2 View Post
                                THX - i guessed/feared to do it in this way...
