Thought some of you would like to know.
Engine just finished a couple of days in the dyno at VS motor. Achevements:
On pump gas (98 octane) and original MOTRONIC: 740 HP@7100 , had problems with rev limiter which limited the output.So he swithced to Autronic.
Test on 120 octane race fuel with NOS: 1065 HP@7700 rpm, 1016 NM@7100 rpm.
Boost: 2,8 bar:
Engine is a stroker based on the diesel short block and tdi crank. Turbo is pts 76
He uses je pistons, "gass ported", eagle rods, redesigned lubrication.
Head:20v ported, different stainless valves ceramic coated, piper double valve springs and retainers, custom cams by own design, approx 290 deg. duration and 11,6 mm max lift, adjustable cam gears.
Looks like Norway is the place to be this summer............
All information from zatzy.com
J
Boost: 2,8 bar:
J
is enough for 1.3 ton car. Unless you are drag racing...
