electric heeeelp
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by powerice
    thanks again, if u guys are thinking about something just post =)
    You, or your car electric can use this info also (it's in German, but there are online translators):
    It's no rocket science .
    Sau
    • powerice
      • Oct 2005
      • 39
      thanks i will give it a try
      • powerice
        • Oct 2005
        • 39
        i have looked closer now under the safebox and you guys are telling me to take out the old harness and put in the one from aby in the same places. but im not really sure with all the cables who is going to the safebox cause the aby harness is not identical to the 7a so my question is how do i really know that im putting the new cables on the correct places as the old? i have seen that the color of the cables from the aby and the 7a is not always the same correct me if im wrong i have some pictures of the cables that i need some explanation in wich places on the safebox its gonna heading and the pictures its not mine i am just borrowing them for a sec.
        on each picture is a code and that is for Bentley wiring diagramsn and i dont have any like that =(
        www.bruket.nu/audi <----- here is the link
        //Johan
        • WabTheKing
          • May 2004
          • 2567
          these are the wire you need to disconnect, note some of these may not be connected to anything anyway
          • WabTheKing
            • May 2004
            • 2567
            these
            • WabTheKing
              • May 2004
              • 2567
              these all enter behind the centre console and the pedels,(on a RHD car duno bout LHD) they are also all taped together, you need to drop the fuse box down as well, there are two clips which you push apart from the top, then the fuse box pannel can be pushed down
              • powerice
                • Oct 2005
                • 39
                ok very nice thanks very much for showing very intrest =) but when i have disconnected all the wires you are showing in wich place should i connect the aby harness. do u have some good pics och explain to show me where the new should be connected??
                //Johan
                • WabTheKing
                  • May 2004
                  • 2567
                  in the birds nest of wires under your stering colum,
                  do you have anyone local to you with an aby?
                  • powerice
                    • Oct 2005
                    • 39
                    yes i know where the birds nest is =)
                    the problem is that i dont have someone with aby near around.. so i dont really know what i should do when im are connecting the new wires in the safebox, cause i dont want to connect the wires on the wrong places. if u understand what i mean.. i dont have any problem to connect the wiring to the engine its just problem with the wiring under the steering wheel and the safebox.
                    • WabTheKing
                      • May 2004
                      • 2567
                      as you disconnect one, plug another in
                      • powerice
                        • Oct 2005
                        • 39
                        ok so the wires that i am unplugging have the same functionality as the wires in the aby harness. for example i unplugging the fat red one in the safebox from 7a, and then plug in a red wire with the same connector and so on?? in that case i im gonna fix it. another question is the old 7a harness i takinng out, does the new one have all the same functionality. so i dont have to use a part of the old to some other functions??
                        sorry if im hard to understand sometimes =)
                        //Johan
                        • aelred
                          • Jan 2005
                          • 761
                          As we are on the subjet of wiring I am in the process of converting a 3B to ABY complete with wiring loom, I found no probem and is fairly straight forward apart from the pulling, pushing, cutting etc, all of the connectors are straight forward swap, except for one and I cannot find any info on it.
                          On the 3B main loom going below the fuse board there is a 4 or 5 way red flat connector, that connects to some further loom, (behind the auxillary relays) but on the ABY there is no such red connector on the main ECU/engine loom, has anyone got some info on this?
                          Your help will be greatfully received.
                          Aelred
                          • aelred
                            • Jan 2005
                            • 761
                            I believed the connector in question is T5h, looking at some of the pictures, but i have no wiring diagram on this one
                            Aelred
                            • audiman
                              • 4827
                              Anyone know what this connector is for???
                              Tom C - www.rcmr.co.uk
                              Audi UR Quattro
                              Audi 100 C3 2.0 5 cyl 115ps
                              Audi B5 RS4 645ps 911nm
                              • mcandmar
                                • Apr 2004
                                • 5118
                                I'm sure i've seen that connector before under my steering column but i cant find any reference to it in the Bentley manual (for 7A CQ). The blue one is cruise control, and the yellow is onboard computer if that helps. I'm thinking climate control for the red one
                                What colour are the wires? ..and what do they connect to on the engine loom?
                                91CQ20v - Gone to a new home
                                93UR-S4 - The Magic Carpet
                                94S2Bus - The Emerald Express
