electric heeeelp
  • WabTheKing
    • May 2004
    • 2567
    on the 3b loom i had a grey and red one and a blue and black which didnt do anything, a light blue one which needs a feed to run the car,
    • powerice
      • Oct 2005
      • 39
      is the 3b and aby loom the same when you connect it to the fusebox??
      //Johan
      • powerice
        • Oct 2005
        • 39
        is there anyone who has the Bentley manual who can refer these pictures on the cables to something?? on each picture it is a code. could some kind person who has this book copy the pages where the info is??
        here is the link to the pics
        and here is the original site
        i cant open .xls files??
        //Johan
        • powerice
          • Oct 2005
          • 39
          hi guys ! today i have taken out the old 7a loom and placed the aby loom. it was little tricky to do, but must be patient. i used the same hole as the old loom used. did u guys do that too? i havent connect the connectors yet, but i should do it as soon as i got time =)
          //Johan
          • aelred
            • Jan 2005
            • 761
            I have done that and as you say patience is a must, on the 3B the battery tray is right nelow the hole to remove and refit the loom, but what a pig of a job as you have to remove the steering dumper as well to give you more room and that is a job and an half
            Aelred
            • audiman
              • 4827
              Have you got to remove the dashboard?? Or can it be done without doing this??
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
              • aelred
                • Jan 2005
                • 761
                I removed the complete dash as I wanted to change the heater metrix.
                Aelred
                • powerice
                  • Oct 2005
                  • 39
                  hi i didnt need to remove my dashboard =) so next thing i got to do is to connect the wires to the safebox. i have marked up everything from the old loom, so now what i had understand from you guys i just need to put the wires with the same color at the same places as the old. i have a question and that is, there is one wire from the old 7a loom who is a thick red one and connects with a black connector to the safebox, and the new loom doesnt have anyone red so thick with the same connector??
                  have a nice holiday
                  //Johan
                  • aelred
                    • Jan 2005
                    • 761
                    you have to run that to the positive to the battery as a extra cable
                    Aelred
                    • audiman
                      • 4827
                      Ok cool, shame i dont get my new loom until end of april Could ave done that mod this weekend! Need to get myself some coils to throw in there. Just to make sure... I take it the A4/S3/S4 coils push into the head OK onto the spark plugs?? I tried one from the old mans Passat V5 and that doesnt pass into the head
                      Audi UR Quattro
                      • aelred
                        • Jan 2005
                        • 761
                        Originally posted by aelred
                        As we are on the subjet of wiring I am in the process of converting a 3B to ABY complete with wiring loom, I found no probem and is fairly straight forward apart from the pulling, pushing, cutting etc, all of the connectors are straight forward swap, except for one and I cannot find any info on it.
                        On the 3B main loom going below the fuse board there is a 4 or 5 way red flat connector, that connects to some further loom, (behind the auxillary relays) but on the ABY there is no such red connector on the main ECU/engine loom, has anyone got some info on this?
                        Your help will be greatfully received.
                        Further to this red connector T5h I found out that this is related to the Air Con, so if the engine wiring loom that you are fitting does not have it means it came out of a car with no Air Con.
                        Aelred
                        • WabTheKing
                          • May 2004
                          • 2567
                          anyone got a diagram for an ABZ engine?
                          • mcandmar
                            • Apr 2004
                            • 5118
                            Told you so
                            91CQ20v - Gone to a new home
                            93UR-S4 - The Magic Carpet
                            94S2Bus - The Emerald Express
                            • audiman
                              • 4827
                              But the ABY loom doesnt have this? Do you need to run the cable from the battery to the fusebox then as a new wire??
                              Audi UR Quattro
