Which turbo is this: k26-2672 GGC 6.92?
  • Jonas_R
    • 3781
    • Country: Denmark
    Can anybody tell what this means, see title.?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    /Jonas R.
    Seems to be, that at least it has RS2 compressor housing, however GGC 6.92 should not be on it .
    Sau
    • Jonas_R
      • 3781
      • Country: Denmark
      Hmmm oki, as far as i know the 6.92 refers to the size of the comopressor whell at the hot side right? And the size on the RS2 is 6.13 which means this is bigger and more like the whell of the 5000 audi turbo, think it is 6.95. But is it good or bad?
      /Jonas R.
      • Audi Parts Guru
        • 1317
        I am not sure where you got the 6.92 from but the rest of the number refers to the RS2 comp wheel only
        S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
        • Jonas_R
          • 3781
          • Country: Denmark
          I got it from the bill that I have from hohenester, where it says there is K26-2672 GGC 6.92 turbo mounted. It should be a Hohenester hybrid turbo. But I can not figure out how much pressure the turbo can handle.
          /Jonas R.
          • kwlw
            • Sep 2004
            • 1025
            let's mystify a bit
            /Jonas R.
            from information I have, 6.92 means, that there is #6 exaust housing. .92 refers to some wheel inside RS2 housing. These are index numbers, not the measurements. RS2 uses .12 wheel, S2 uses .13. However there is some mystery, because I can nowhere find wheel index .92 in the K24 catalog. If I'm correct, then it means, that your contains .92 wheel from K26 turbo used in 10v turbo. Probably 5000T with KH engine or porsche 944.
            So I make a hyphotesis that you have something like porsche 944 turbo with RS2 cold side housing and probably rs2 cold side wheel. . No idea what code letters mean.
            I'm not turbo specialist , however good in making assumptions in situations where lots of facts are missing . Sometimes I'm right, however usually - not. Take that into account.
            Sau
            • Jonas_R
              • 3781
              • Country: Denmark
              Yeah oki, so now the good question is how much the turbo can take compared to an RS2 unit. However i have emailed hohenester and asked them about the turbo. Will post what ever they say.
              /Jonas R.
