Well at least you have a clean ISV!
Go and buy a new cable. If you were suggesting trying to lubricate the old one, why make extra work for youself. If the idle is normal with the cable disconneced then it proves that the control system is ok (Throttle pot, ISV, ECU, linkage) so the only thing between the pedal and the throttle body is the cable.
Replace cable, enjoy car and give you transmission a break!
