(Very) High Idle Problem....
  • twoqu
    • Sep 2003
    • 3103
    Well at least you have a clean ISV!
    Go and buy a new cable. If you were suggesting trying to lubricate the old one, why make extra work for youself. If the idle is normal with the cable disconneced then it proves that the control system is ok (Throttle pot, ISV, ECU, linkage) so the only thing between the pedal and the throttle body is the cable.
    Replace cable, enjoy car and give you transmission a break!
    • Ednamillion
      • Nov 2005
      • 8
      But I'm properly paranoid now, twoqu. Don't I (shouldn't I) have a spring-loaded accelerator pedal? Will check this evening (but will I recognise it?) but could that be banjaxed/dislodged and hence not allowing the throttle itself to return to a 'home' position at it's stop?
      I'll get this thread to three pages yet!
      Thanks for everyones help...
      Edna'...
      • twoqu
        • Sep 2003
        • 3103
        Well you said the pedal wasn't any different!
        Ok, disconnect the cable from the throtle pedal. If the pedal moves freely without hanging up then its the cable!
        • maRS2
          • Oct 2003
          • 366
          • Home: France Current: Thailand
          changing cable is a 10 mn job
          RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
          • twoqu
            • Sep 2003
            • 3103
            #20
            I don't think the throtle pedal has a return spring
            It relies on the force from the throttle body to return it. Ergo if you have disconnected the cable from the TB and everythings ok, then it must be the cable sticking!
