2234 (Blink Fault Code), VAG1551/2 Fault Code Number 00532 Supply Voltage Problem, ECU supply voltage too low or too high
This started showing up right after I upgraded to RS2 software. No real instructions I could find to diagnose and fix the problem. Anyone else ever pull this code? No running or drivability problems at all, just a constant CEL.
. I've simply checked on the opposite side of connectors where +12v comes to ECU power terminals, but however this may be not the your case. Sorry for confusing.
