any one help please im trying to read blink fault codes as per s2 central all i get is that the lamp is permanently lit
problem is i fitted boost gauge yesterday and cant get more than 0.4 bar any time.
any coments
thanks martin
strange, thats what i thought i connect lamp black conector and blue conector and it lights up ingnition on or of jumper in or out tride and tride agian still same
Only thing I can say is:
when you insert the jumper, be sure you do it securely. A couple of times happened to me while bypassing, that the connection was interrupted just a fraction of sec. before the 2 seconds (this because I wasn't holding the cables firmly enaugh) so the stuff didn't work.
If you did everything correctly and still doesn't work, maybe Mihnea and Paul N. can tell you why.
