blink codes
  • marty
    • Nov 2003
    • 55
    blink codes
    any one help please im trying to read blink fault codes as per s2 central all i get is that the lamp is permanently lit
    problem is i fitted boost gauge yesterday and cant get more than 0.4 bar any time.
    any coments
    thanks martin
  • Pisobiker
    • 1175
    that is strange.
    I did the same too, following S2Central.net instructions with the bypass cable and 12V light. And it worked fine.
    Are you sure you bypassed the correct poles for at least 2 seconds before taking bypass off?
    Marco
    • marty
      • Nov 2003
      • 55
      strange, thats what i thought i connect lamp black conector and blue conector and it lights up ingnition on or of jumper in or out tride and tride agian still same
      • Pisobiker
        • 1175
        Sorry Marty, cannot be of help.
        Only thing I can say is:
        when you insert the jumper, be sure you do it securely. A couple of times happened to me while bypassing, that the connection was interrupted just a fraction of sec. before the 2 seconds (this because I wasn't holding the cables firmly enaugh) so the stuff didn't work.
        If you did everything correctly and still doesn't work, maybe Mihnea and Paul N. can tell you why.
        Marco
        • marty
          • Nov 2003
          • 55
          Tried again still no joy got the dash in bitts now ill try wiring the MIL light see wat that does
          thanks marco
