RS2 inject0rs?
  • Ski
    • 2591
    RS2 inject0rs?
    helo *waves*
    im greedy and would like more POWER!!!!!
    i have a bog standard s2 with a good intentions to mod it up.
    question is rs2 fuel injectors, i belive there are pple who have superglued them onto their s2's.. my question :
    how is the bhp effected?
    how much it cost?
    how much it cost to fit?
    any risks on a 170k engine?
    also.. does anyone know any GOOOOOD audi engine mechanics in the manchester area that are farly cheeap as im sick of paying £80 a hour to the audi dealer for the simplest of things!
    The geek with the S2
    ABY Coupe
  • Pisobiker
    • 1175
    No gain on using RS2 "Green Bosch" injectors without any other software and hardware upgrade.
    Only fuel consumptions way higher and big clouds of dark smoke for over rich mixtures from the exhaust
    Marco
    • Ski
      • 2591
      am i right to say this should be done before adding a mtm chip?
      ABY Coupe
      • Pisobiker
        • 1175
        Your origianl fuel injectors will be more than enaugh to exceed actual power capabilityes of original K24 turbocharger, which is 270-280 hp.
        Marco
        • Ski
          • 2591
          how do u pple get so mutch s2 knolegde? *gives a jelous look*
          cool... so for now.. best thing to do is..
          air filter, exchaust n chip.. then go onto the big boy stuff like turbos etc..
          ABY Coupe
          • Pisobiker
            • 1175
            Marco
            • Audi Parts Guru
              • 1317
              Re: RS2 inject0rs?
              are you sure about that
              S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
              • Ski
                • 2591
                Should i use a special brand of glue? :confused:
                ABY Coupe
                  Welcome Ski
                  Get your ECU fitted with the Home Fry chips , really good value and an incredible difference
                  My car has 180 odd k miles and is running the 280 bhp chipset and no problems yet, apart from the clutch giving up..
                  • Doug_RS2
                    • 3847
                    You will not need any glue - where did you get that info?
                    The RS2 injectors are a straight swap for the originals - and they are a push fit, both ends - just be careful not to nip the rubber seals or they will leak.
                    • Ski
                      • 2591
                      ABY Coupe
