Ive finally traced the source of the water leak that from needing a regular top up suddenly became a whole lot more serious over the weekend - with large quantities of steam shooting out from the front of the car
. Finding where it was coming from was another matter as its virtually impossible to see clearly under the manifold!
The burst in the pipe is just visible (and I mean just visible!!) by squinting through the gap between the power steering pump and the inlet manifold - So it looks like the length of hose that comes off a metal pipe (think the one the heater matrix feed is connected to but I cant be sure) then goes into the block at the top front, as was originally suspect and is a common problem I think. Under pressure and with the car hot it’s squirting out coolant like thru a nozzle! Marvelous!
Problem is getting to the beggar to put it right!! Looks like its the most inaccessible bit of pipe on the whole engine to get to (well nearly!) I think I’ll have to move the power steering pump for sure, or even remove it to get near.
Any top tips on the best way to proceed guys!??
Paul
Paul
Was hoping I could move the pas pump without having to disconnect the whole thing! However, I do need to drain and refill the system to see if I can cure the warning light that I inherited, so could be an opportunity! And Ive also got aircon in there just in case it wasnt tight enough!
