For the last few weeks ive been having problems with hesitation cutting out etc, thought it was down to using optimax as it ran ok on bp ultimate but no-one else has been having similar problems so suspected something else was a miss. well today it all went **** up , ive spent the last 5 sodding days fitting konis, got finished today and the thing wouldnt start.
thought it'd got damp, sprayed wd40 everywhere, spark was there, plug was wet with petrol so thought must be damp, towed it off and started ok but wouldnt tick over on its own.:mad:
so went for a drive not letting it fall below 2k rpm, wont accelerate over half throttle just cuts out, did about 15 miles and eventually started to idle on its own blip the throttle and nearly cuts out. still wont boost over 0.3bar, will start on its own but only after 10secs or so.
it looks like the earlier problem i had with it not boosting over 1.3bar has got a lot worse, definately feel its fuel related.
question is:-
will a dodgy fuel pump cause this, does the pressure between the pump and the fpr remain constant or between the fpr and injectors remain constant? thought it could be a dodgy pump struggling to fuel over 1.3bar, so now is struggling to feed over 0.3bar since its not been started for a while.
ill be changing the fuel filter tomorrow.
where the hell is the fuel pump on a 3b coupe, thought it was screwed into the top of the tank like in dougs pics of his motorsport pump installation but it isnt.
is it under some heatshield or something?
sorry for the rant but i have to be back in london on monday
:wacked: :mad:
martin
question is:-
:wacked: :mad:
martin
