Has anybody tried this to the cooling system ?
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Hi,
    Recently came to this:
    http://rallynuts.com/motorsport/DEI_..._Relief_96.asp
    As we have quite warm summer at the time and I have black car, this sounds like panacea. Has anybody tried that ?
    Sounds too good to be true, or at least not to be simple painted water ...
    Sau
  • WabTheKing
    • May 2004
    • 2567
    Originally posted by kwlw
    Hi,
    Sau
    looks like the same sort of stuff as that wetter water stuff from tweeks
      Yeh, thing is since the S2 can only use Audi specified coolant would you trust adding a 3rd party additive too the system?
      ( God i sound like Mr OEM! )
        there was a discussion about water wetters last year
          LOL i see i'm consistant in my views
          • WabTheKing
            • May 2004
            • 2567
            why?
            i used water and normal anti freeze for years no problems
            • Fat Audi 80
              • 10547
              *Enters Stage right*
              I would stick with the OEM stuff myself.
              *Exit Stage left*
              The Perfectionist
              • PeteRR
                • 1326
                *Exit Stage left*
                class!
                I've used Water Wetter in mine (basically similar stuff to Rad Relief). It didn't seem to make much, if any difference in mine.
                I'd just stick with a fresh mix of G12+ and distilled water myself too.
                • WabTheKing
                  • May 2004
                  • 2567
                  but what differance does it actually make?
                  • dan_b
                    • Sep 2003
                    • 3670
                    I tried Water Wetter for some reason and can honestly say I noticed no difference whatsoever. I guess it's a bit like homeopathy.
                    • kwlw
                      • Sep 2004
                      • 1025
                      Thank's. It seems to be same as I've thought - coloured and overpriced water
                      Sau
                      • aelred
                        • Jan 2005
                        • 761
                        Why does the S2 have to run with specified Audi coolant? Is it because is pink in colour?
                        Aelred
                          Colour coding is everything!
                          • SteveH
                            • 4460
                            Any antifreeze for a mixed alloy/steel system will be ok. I believe the only problems you might experience are if you mix different types of antifreeze/rust inhibitors... G12 and G12plus aren't special, other than being pink!
                            91 Modded 3B
                            14 A6 Avant Black Edition
                            • Corey
                              Banned
                              • Sep 2003
                              • 2793
                              If you read the blurbs that come on the packets for most of these water wetter's, they say that the properties are reduced the moment you introduce antifreeze to the mix. Sort of negates the effect IMHO.
                              Stick with good 'ole antifreeze.
                              Corey
                              01636 822288
