Originally posted by The Spanish
I want to have the safest setup for the engine so the Metal Headgasket would be better no?
Please enlight me
You should be able to see the head gasket sticking out of a back corner. Or you should be able to feel those brass rivets under the head at the front sides(the head overlaps the block)
Originally posted by The Spanish Marco and Minhea or anyone else,
For my setup with the RS2 turbo + injectors + Exhaust Manifold should I get the Metal headgasket?
I thought they were the same on the ABY and ADU
Please enlight me,
Rafael
Umm, well, your ABY might have the paper head gasket from the factory... I've never had real problems with it but it would be safer for you to run a metal one, as it will slightly drop the compression ratio and allow you to run safely with no knock.
Cheers,
Mihnea
Originally posted by Mihnea It's all up to you actually, if you don't go often to 6+k RPMs in 6th gear, then it's not so recommended to drop the CR...
HEY :eek2: Mihnea, we have speed limits and cameras that nail are arses!! That would be prison time for doing that. Wouldn't catch me doing that whilst chip tuning Thats about 150-160mph??? Nop, not me, i never go over 60mph
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
