Boost Control
  • Billman
    • 4129
    Boost Control
    Hi, i was reading something on Motorgeek and it suprised me.
    There where said that in the Stock Motronic the boost is controlled by the WGFV (the ECU) only in Full throttle. In part throttle it is controlled only by the Wastegate (spring tension). That would mean that in part throttle, even if the Turbo and the exhaust gases are capable for more it is not allowed. Wound it mean that it would have a worse throttle response?
    Is it right? Can be something done there except of changing the wastegate Spring?
    Go Holset or Go RS4
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by Billman
    Wound it mean that it would have a worse throttle responce?
    Don't know what is right, and what is wrong, but it can be corrected by electronic boost controller. This is nice, gives you more low down power (if you are not greedy and set it to let's say 0.8 bar ), however ECU loses important instrument to control the boost then it needs.
    Sau
    • Mihnea
      • 1288
      Absolute ********!!!!!!! The stock ECU controls boost anywhere above 30% throttle opening!!!
      jeez I still can't believe how much BS is spread on the internet...
      There where said that in the Stock Motronic the boost is controlled by the WGFV (the ECU) only in Full throttle. In part throttle it is controlled only by the Wastegate (spring tension). That would mean that in part throttle, even if the Turbo and the exhaust gases are capable for more it is not allowed. Wound it mean that it would have a worse throttle responce?
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • Billman
        • 4129
        Cool man! Thats why i am asking it here to become the correct answer.
        Go Holset or Go RS4
        • BRY
          • 3755
          Where does it get the signal from?
          If the throttle pot is shot, would it know that it is open beyond 30% ?
          • Mihnea
            • 1288
            Oh hey, lemme email you the motronic function descriptions, I think you'll understand better this way, huh?
            www.MRCTuning.com
            info@MRCTuning.com
            Workshop Directions
            • WabTheKing
              • May 2004
              • 2567
              • WabTheKing
                • May 2004
                • 2567
                say what you see!
                • Billman
                  • 4129
                  @Mihnea
                  Now that you are here, can you tell us at what Intake temp the motoronic starts to retard the ingnition?
                  When the Intake Temps are high it also takes the boost back and how much?
                  Go Holset or Go RS4
                  • BRY
                    • 3755
                    Go on then, if you must, or you could just answer a direct question
