Pelle,
this is how the dizzy should look at TDC
the bottom pully should line up with the marker, (if you cant find a marker i put a bar through the spark plug hole in cyl no. 1 and wind it by hand on the crank to TDC
dot on the top pully should line up with a arrow cast into the rocker cover
dosent really matter which way you put the dizzy in as long as you can get the plug on,
then just line the two lines on inner wheel and the outer casing of the dizzy
job done!
HTH
Regards
Will
job done!
HTH
Regards
Will
