Well,
If i just touch the gas pedal very gently it makes the car stall, or the idle drops from 900 rpms and down to 400 rpms. It then gets back up again to 900 rpm. I thnik this is very strange, cuz the idle is very smooth when it is at 900 rpm, is is not going up and down.
Well it is not the ISV, MAF, TPS, N75 all brand new.
So is there any other sugestions to what might cause this problem? I mean I dont have a clue to what the hell is causing this? Could it be a bad O2 probe og perhaps the plugs are bad? Well any suggestions would be helpful
/Jonas R.
/Jonas R.
