The allingment was over the plastic bit, 3-4 mm off center where the marking on the housing is.
Should the marking on the housing be allingned tothe centerif the rotor arm ??
Audi S2 Coupe - 92
Koni + H&R. PowerFlex bushes. 3" Exhaust
RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
Best ET 2007 201m 8.15@140km/h
Best ET 2008 402m 12.34@177km/h
My Project http://www.s2forum.com/forum/showthread.php?t=16997
Audi S2 Coupe - 92
Audi S2 Coupe - 92
i have one small problem the rotor arm and the line is impossible to gett in line with the line on the housing.
its the same as before now 3 mm off.
Is it possible to adjust the inner "line" ???
Audi S2 Coupe - 92
You see the round rivet (about 4 o clock in your image) over the cover for the dizzy clamp, remove that cover and there is a nut underneath. Undo the nut and rotate the dizzy till the lines align.
Is the dizzy the outer housing or the inner ?
My car run well with apperently the Ignition a bit of ??!?
Audi S2 Coupe - 92
