Benefits of a 7a exhaust cam?
  • s2driveruk
    • 12696
    ok, been looking about and have been trying to get a definitive answer on the benefits of chucking in a 7a exhaust cam in my 3b....
    My current setup is:
    3b
    Stock K24 turbo
    Nugent homefry
    stock exhaust manifold and downpipe mated to a cat back s/s exhaust
    If i change the 3b exhaust cam for the 7a (or a complete 7a head) what will i 'get' back in terms of performance/sound/driveability/flow/ etc.
    From what I can see i get a bit extra flow towards the top end but whats the compromise?
    I need to change the rocker cover gasket due to a weep and what's the interval on the cam chain as i think mine is rattling and at 174k its original as far as i know....
    David
    1992 3b S2 Coupe
  • SteveH
    • 4460
    David, I think you'll loose your bottom end torque if you throw a 7a exhaust cam at your setup. It does open the top end up, however, this isn't going to help with the k24, as it will have run out of guts at the higher end of the rev range.
    91 Modded 3B
    14 A6 Avant Black Edition
    • s2driveruk
      • 12696
      Cheers Steve....really is no point then on that until a change of turbo is more likely - its not on the horizon with a house move worse luck lol
      David
      1992 3b S2 Coupe
