I had an issue regarding what i thought was a slight misfire but it seems that the problem is now more hesitance. the car nearly cut out at idle this morning which set me wondering whether i have a fueling problem.
the is seeming ever more lethargic so i thought maybe i have the fuel pump getting weak or a blockage in the fuel filter or injectors. do you get any noise from the pump as it starts to fail which would let me know that it is failing?
