Forge Dump Value Sound?
  • RustyNut
    • 1433
    • Home: Zambia Current: United Kingdom
    Will a Forge 007 work on an S2?
    Old Stuff Reborn.
    • diesel des
      • 3896
      Yes.
      • PeteRR
        • 1326
        I might be selling my black 007 Forge in the future.
        I'm going through an O.E. phase for the ur!
        • adamw
          • Dec 2005
          • 348
          • Country: Shetland Islands
          Originally posted by andrewd
          It's not su much "wasting boost", more the fact that a load of air already measured through the MAF sensor suddenly leaves the system, causing the car to temporarily overfuel.
          so if it temporarily overfueld then flames would spit out the exhaust due to the fuel/air mix at that time?! corect me if im wrong?!
          cheeRS adam
          RS2+
          • philS2
            • 356
            it does't on mine mate,just a bit of black smoke.but i'm in the process of going with recirc and cone anyway as the dump valve on mine holds open a bit while cruising as if the spring isn't strong enough so it'll be overfuelling the whole journey
