Hi all
Just been reading up about the different springs you can get with the forge DV. Which are designed for how much presure your car makes.
What colour spring should you use for the S2. I just wanted to check as mine doesn't seem to make much of a sound at all. The spring in mine is blue but don't know where to find out which one is recommended.
Thanks
Ian
Thanks
Ian
