if that is the case,should i also change to a yellow spring instead?If im boosting with a yellow spring,wont this mean that if the boost reaches the 1.6bar,then the DV will open,and isnt it possible that this way i wont be able to reach the estimated overboost value?
for example,if i have a program to reach 1.8bar overboost,and 1.4steady boost,which spring should i use?blue or yellow?
With the DV i have now,with the blue spring,i do hear hissing sound on gear change.Doesnt that mean that the DV is working properly,opening to let excess air out?
