My UrS4 AAN is using loads of coolant!
It will go from the max level to below the minimum in a week or 170 miles!!!
I've had a coolant pressure test and it holds hot and cold at 1bar...so no leak.
The viscose fan was replaced a week ago as it had a lot of play in it and i thought the coolant use would slow once the viscose fan was back on form...but no.
I can't tell what temperature the engine is running at as the sensor for the guage has gone and there is more pressing things to spend £140 on replacing.
The head gasket is healthy and the engine has never overheated...so I'm at a loss!
Anyone got any ideas about what the problem is!?!
. Sometimes cars leak only in high rpm. You cannot find where it does when car is idling.
) , try to put your hand to the back of the engine (let it cool down) from UK drivers side
. You must see white connector as guide - nearby there is a hose, try to trace it by hand to find the valve, and if it's wet - you'll need a new one, or at least check it. It's not possible to see leak usually. I've paid 30eur for new original teile.
