Originally posted by Briggsy
Hi!
You could certaintly try and bypass the pump temporarily by getting some 19mm copper pipe. You will need to get a fitting with approximately the right angle (no pun intended!). Join the hoses together with some extra clips and see if that makes any difference.
If its the original then its likely that either the stubs are brittle and have cracked or that they have gone soft. Either way the connection might seem ok but as the temp increases perhaps the seal is being broken. You should still have some evidence of coolant loss.
Oh and if you were worried about the cost of the MFS, don't ask about the pump!
In fact, if you are going to fiddle with the pump connections, go and find something to allow you to reconnect the hoses NOW! At least that way the car can still be driven if there is a problem with the pump.
