Aaaaaaaaahhhhhhhhhhhhh!!!!!!!!!!!!!!!
  • sacs2
    • Feb 2005
    • 83
    Ive just got my s2 going again after a turbo change and injectors.head gasket etc. Took it down the road for 10 miles at no more than 2000 rpm and its just spewed its guts out all over the drivewater and oil mixed AAAAAAAAAAAAAAAAHHHHHHHHHHHH!!!!!!!!!! Not a good sign
    IF it aint broke DONT! fix it
  • terrybullwon
    • Mar 2006
    • 8782
    Chef
    • s2dude
      • Nov 2005
      • 1631
      Oh dear
      Doesnt sound good....
      Is it the head gasket thats gone??!
      • Ross
        • Aug 2005
        • 3399
        Did you do the head gasket yourself or was it at a garage?? if I'd just paid up to have a HG done and it failed like that, I might be having a few words. Especially if it was a dealership - probably had the work experience lad do it...
        • sacs2
          • Feb 2005
          • 83
          HA HA no mate i did it but it was done right with lots off experience. im well pissd off tho as you can imagine. used all the top bits and pieces as well. It was fine when i heated it up on tick over. did that for 3 days just to make sure everythin was ok before i took her out. Corey from Quattrinics told me not to take it over 3000 rpm so i didnt go above 2500 and it seemed fine for the first few miles then everythin went pear shaped. OH well guess i will get the tools out again eh
          • Ross
            • Aug 2005
            • 3399
            Agh I feel for ya... yeah all those gaskets etc sure add up! I had a huge bill with Vagparts when my rebuild was done a few months back!! At least you dont have to worry about the huge labour bill tho...good luck getting her back running!
            • sacs2
              • Feb 2005
              • 83
              Thanks M8. Ive spent around 2k on the best bits for her so it makes it worse i guess.Im sure it will be worth all the time and effort in the end ha ha. Oh well into the garage i go.
              • Jas11n
                • 5067
                Jeez man, you ain't having a lot of luck
                Where did it spew it's guts from then?
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • sacs2
                  • Feb 2005
                  • 83
                  not too sure yet M8. Will let you know where i get it back to bits again .
                  • sacs2
                    • Feb 2005
                    • 83
                    Right, its dumped mayo all down the back of the engine and onto the gearbox bell housing? Im not convinced that the head gasket has failed but i do know that the only way you get mayo is oil & water mixed. But how can a brand new H/G fail after just 5 mins down the road at no more than 3000rpm? There is more oil in the rad than water,is it possible i could have put a water pipe onto an oil pipe? i cant have i put everything back exactly the way it came off
                    This is diong my head in now HA HA
                    I guess its off with her head to look closer and see if it has failed or not
                    • philS2
                      • 356
                      was the head gasket the original problem then mate?
                      • sacs2
                        • Feb 2005
                        • 83
                        Yes it was M8 but i put a new turbo on while it was in bits and some rs2 spec injectors just for gud measure
                        • BRY
                          • 3755
                          Did you have it tuned for the RS2 injectors?
                          • martinjs
                            • 3205
                            Did you fit a metal head gasket?
                            • martinjs
                              • 3205
                              What was the outcome of this thread btw? http://www.s2forum.com/forum/showthread.php?t=17630
