Please help here guys
Got the car back together and its running hunky dory. Loads a new parts, new plugs, etc etc
Took Andy P out for a spin earlier and we both agreed it is no way as quick as his S2
(whcih is only chipped with Samcos)
Now I have thought this for a while but here is the chain of events..
1// MTM chip fitted (by me and I am 95% it is genuine) and car went like stink but idle seemed dodgy after chip fitting? (could be that as the car had been laid up for a few months and had boost leaks it only felt like it was quick...and it actually wasnt that quick!!)
2// fast forward..> ALL boost leaks fixed and car was boosting to 18psi tonight (standard wastegate spring and standard S2 map sensor) but when you floor it it just seems like it almost has the brakes on a bit (they are not!)
Symptoms//
Andy reckoned car ran hotter than his...temp gauge showing max of a notch or 2 over 90 but it never goes below 90 when warm.
Definately didnt pull as aggressively as it should do boosting to 18psi.
Poor idle when warm...hunts all over the shop (I have totally and thoroughly cleaned the ISV, Firetrap, PCV and MAF)
Bit hesitant under 3k rpm
ALso/////
Clutch seems fine
i was thinking tomorrow to check
1// That Timing is spot on
2// Dizzy (3B)
3//If all that is ok then I was going to revert to the stock chips and see if it runs as it should even if I lose 6 psi boost
(I think its 12psi stock is it??)
Does anyone have any ideas on what the hell could be wrong here please??!!!
ive spent too much time and ££ on thsi car to not have it running well!!!
THANKS IN ADVANCE
(whcih is only chipped with Samcos)Now I have thought this for a while but here is the chain of events..
Symptoms//
ALso/////
Clutch seems fine
2// Dizzy (3B)
(I think its 12psi stock is it??)Does anyone have any ideas on what the hell could be wrong here please??!!!
THANKS IN ADVANCE
