Hi all
I think I have an issue with my turbo cooling pump and just need a bit of clarification from the experts please. I have read the number of post in this regard and think my issue is the switch that triggers the pump. On my old S2 the pump and fan used to come on as soon as I switched off the car when the main rad fan was running. This does not happen on the RS. I have checked the pump itself and can hear it spin up when I put the ignition on.
Does anybody have a pic of the switch that triggers the pump (location etc). I gather it's near the front of the engine down by the thermostat. Is there any way to test this switch (resistance, stick it in the kettle etc) I see there are also a few options to fit other switches (LT and FAE). Is there some more info on these, such as what cars they are fitted to. This will make it easier to locate them here in SA.
Thanks
Andre
Thanks
Andre
