Can anyone tell me how to check the tempreature gauge,its not working on my 3b, a I understand you short a wire, but I need to no which wire cheers.
tempreature gauge
Most probably you have faulty MFTS, not the wiring. BTDT on three cars (including mine). After MFTS replaced - it started to show coolant temperature.Originally posted by 220bhpCan anyone tell me how to check the tempreature gauge,its not working on my 3b, a I understand you short a wire, but I need to no which wire cheers.
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.com -
You are welcomeOriginally posted by 220bhpThanks for the advice Sau I will get a new one, its madeness to run these cars without a tempreature gauge,.
Many thanks Lou.
Note, that new MFTS (if it's really new) will have less pins than old one. It's OK.
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
I just got my mfts through the post, and sods law the gauge works again
But i will still change the sensors get the small one as well
ChefComment
