Gauge readings fluctuating?
    Here's a strange one for you all to think about
    I've had this a couple of times, that I've noticed. Driving along, look down at gauges to notice I have 1/2 a tank of fuel, think thats funny sure I had 3/4 of a tank just now, then notice the temp only reads about 65deg. Then I remember driving home from holidays, similar thing and when I stopped and restarted the engine the fuel level and temp readings went back up to normal, so I just shut off the ignition for a couple of seconds and switched back on, sure enough the gauges slowly came back up to 3/4 of a tank and 85 deg.
    Seems like bad voltage regulation or a high impedance contact somewhere, maybe a relay or the ignition switch? Any ideas?
  • Jas11n
    • 5067
    Voltage regulator on the back of the clocks? The little three legged dude.
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
      Something to replace when I do my plasma gauges then, eh?
