Rotor Arm
  • ian_jemo
    • Aug 2004
    • 284
    Rotor Arm
    Hi all
    Does anywhere know where to buy a rotor arm from for the dizzy?
    Went to Audi and they didn't know which one I needed, I presume its a bosch part and I can buy it pretty much anywhere?
    Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • Paulgo
    • Jan 2005
    • 498
    ive been meaning to check to see if a rotor arm from a Golf 16v (I think!) will fit - Marty at Vagparts remembers something about one possibly being used and if so they're easy to get hold of.
    Of course changing the b*gger is another rmatter!!
    cheers
    Paul
    Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
    Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
    • AUDI9020V
      • 653
      yep its right a golf one fits the 20v ,i fitted one f on mine,my old rotor is bonded on so u need to smash it to get it off, but do it careful and i mean careful dont get the mogrips on and twist or thats one dead dizzy,so nice n steady mogrips or pliers crush it,but also remember to cover the dizzy up with a rag so bits dont go all over it.
      1990 100 2.2 10vqt 82k miles(now dead)
      1990 90 2.3 20v 166k miles
      1988 90 2.0 10v 181k miles
      oh and a polo for work.
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        Don't know if it is relevant to the S2 dizzy, but years ago a mate had an old 5cyl Audi Coupe (1.9L engine? ) and he replaced the rotor arm with one from a 5cyl Passat.
        I seem to remember that it was because the Audi's rotor arm had a mechanical rev limiter (spring loaded contacts) and the Passat one didn't. After that he used to rev that thing to over 8K rpm and the poor old thing just went for ever
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Smash the old rotor off and glue the new one on. Get a 7A rotor and file down the tip to the same size as the old one, or use a Toyoa rotor P/N 19102-02020 according to Mihnea.
          SS
          • martinjs
            • 3205
            This is the one martyn told me to use a few years ago, 052 905 225C, its from a polo.
            • caterpillar
              • 2480
              lada rotor fits tooo...
              • ian_jemo
                • Aug 2004
                • 284
                Cheers guys looks like I got plenty of options,
                If the old one is bonded on, presume I would need to bond on the new one, or does it fit nice and tight? Didn't want to put one on and have it explode everywhere
                Ian
                • AUDI9020V
                  • 653
                  The 20v Of Mine Was Bonded On I Just Smashed It Off Very Carfully Then Pop The Golf One On Works Fine.the Spline On The Shaft Holds It In Place.
