Hi everyone,
I have read alot of threads about overboost protection coming in and violently cutting the boost... Well this is what is happening to mine now. The strange thing is, it has happened immediately after changing from stock 3B airbox (with K+N panel filter) to an Apexi cone filter. This means the only part of the boost tubing (which was previously holding boost fine) that was removed is the MAF. This makes me believe that it isn't a boost leak causing this.
I want to clean the MAF but IPA is not available in Romania, is there any reason why I should not use carb cleaner spray? I can get that here, or maybe acetone (nail varnish remover) Please let me know befroe I kill my MAF by using the wrong stuff...!
When I first had the car, this overboost problem was apparent, and not knowing anything about it I took it to a turbo specialist friend of a friend... he said he had to replace the MAP sensor in the ECU and that sorted the problem. (I dont knw if thats what he did, but the car has been fine for 6 months now.
Could a simple swap of air filter cause this? Could the cure be to wind out the preload on the wastegate spring a touch? I have a funny feeling he did something with this, was whe I got it back originally car worked fine (hot day) then when it rained and I booted it down a slipo road onto the motorway overboost protection came back, I returned to him and he "backed it off a bit" Again, I dont know what he did, but it was fine again afterwards,
The 3 main culprits seem to be dirty MAF, boost leak, and MAP sensor.... is this correct...?
Thanks for any help or advice
Chris
Chris
Clean the MAF connector contacts carefully and be sure they are making a good connection. Plug back in and try again.
