Motor Error
  • valjo
    • 1110
    • Country: Latvia
    Motor Error
    today i link my car with vag-com diagnostic item. I found out this error:
    00513-003
    Geber fur Motordrehzahl-g28 kein Signal!
    what is this? What should i do to repair thise sensor or what it is?
    BTW: she goes like a rocket !
    thanks!!!
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
  • Mihnea
    • 1288
    Valjo, if you've read the fault codes without a running engine, the fault code is normal. Normally you can't have a running engine with that fault code (motordrehzahlgeber= engine speed sensor)
    HTH,
    Mihnea
    www.MRCTuning.com
    info@MRCTuning.com
    Workshop Directions
    • valjo
      • 1110
      • Country: Latvia
      yes i was runing diagnostic when my engine didnt runing! but we ran diagnostic also in my mates s2 whitch didnt have engine on, but he had no errors ;(
      any new ideas ?!
      Audi Coupe S2 1993
      Audi V8 4.2 1993
      Audi cabrio 1998
      • Mihnea
        • 1288
        any new ideas ?!
        Don't worry, that fault code only comes in once in a while on a non-running motor, so stop bothering, your car has no problems!
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • valjo
          • 1110
          • Country: Latvia
          Thanks Mihnea!! i have just read somthing about g-28. I read that if the g28 fails, car wont start anymore, but my has no problems !
          Audi Coupe S2 1993
          Audi V8 4.2 1993
          Audi cabrio 1998
          • Vagsport
            • 533
            As Mihnea wrote, your car is fine. Your mates one didn't give the error reading with same condition as yours (not running) doesn't mean yours is faulty, it just depends on where the flywheel was when the engine was stopped.
            Siena
            • valjo
              • 1110
              • Country: Latvia
              thanks for alll info!!!!
              you really make me happy!!
              Audi Coupe S2 1993
              Audi V8 4.2 1993
              Audi cabrio 1998
              • *ZenithalRavage*
                • 216
                lol, hey but speaking of flywheels, anyone here installed aftermarket lightened one?
                *ZR* S2 R.I.P.
                Visit *ZR*'s Hideout!
