Stages (like with Cosworth)! Example for a sticky?
  • T2Andy
    • 1903
    QST and DAHLBACK have a stage system but their prices are redic it would have cost ross about 12k qst or 24000 e at dahlback
    • 1975DCS
      • Sep 2006
      • 258
      I have red some threads about cams and I am bit confused with all the information and data...
      Do I need other cams for a S2 3B if I would go 350-370 BHP? If yes will that be exhaust cam only? Or both inlet and exhaust? What will the cam do? Add Midrange? At top end? 7A? RS2?
      Like I said, maybe the info is out there but reading just confuses me further...
      • Chris M
        • Sep 2003
        • 1030
        7A exhaust cam helps with turbo spool up and is a popular mad with most here. 7A inlet can be done too but may reduce low down torque but improve top end power. I've got a 3B but wont be fitting the 7A inlet cam as i know of at least 2 big power S2's that have sheared the dizzy drive gear off the back of the cam although i could try get it strengthened. Depends what your after.
        Cheers,
        Chris
        Cheers,
        Chris
        Silver S2 Avant : Sold
        • Billman
          • 4129
          They shear it off because of the power?
          As far as i know the 7A Exhaust cam will also move the torque a bit up the RPM scale.
          Go Holset or Go RS4
