Catch tank help please
  • terrybullwon
    • Mar 2006
    • 8782
    Bit lost here, i sort of have it but i am not 100%
    Right.......
    My catch tank (insert)
    So the two top inlets.
    1. one lenth of 8mm hose from the back of the cam case to the top of the catch tank.
    2. one lenth of ..mm hose from the top of the tank to the original 30mm inlet at the bottom of the engine block
    Just like this?
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    please?
    Chef
    • s2avant
      • 2426
      That's basically it.
      One to the back of the cam cover and the other to the outlet on the block.
      I had an adaptor made to convert the 30mm outlet on the block down to the same size as my hoses.
      Ben
      • pastures16
        • 2058
        do you get rid of everything in between such as 4a/6a and 13 in the pic and what about the pipe above no 7 ?
        94 s2 avant
        aoc member 1116
        • Jon441cc
          • Dec 2005
          • 2061
          • terrybullwon
            • Mar 2006
            • 8782
            Yeah it all goes in the bin, its probly ****** any way
            Ben, where did you get your hose reducer made?
            Chef
            • terrybullwon
              • Mar 2006
              • 8782
              Cheers Jon, i dont have one to go the atmosphere? if you look at my catch tank
              Chef
              • Jonas_R
                • 3781
                • Country: Denmark
                No but then you need to make some thing that went to the air, and it preferly has to be bigger then your inlets.
                I mean the air needs to go somewhere, and it cant right know.
                /Jonas R.
                Sleeper S2 Avant +450
                A6 Avant 2.7t Stage 3
                Audi S2 Coupe RS2'ed
                • s2avant
                  • 2426
                  The other halfs dad made it for me along with some other bits ages ago. it's only a turned down section of bar with a hole drilled through it. Any engineering place should be able to knock something up.
                  Ben
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    cheers ben i know just the person for the job, was yours metal?
                    Chef
                    • Jon441cc
                      • Dec 2005
                      • 2061
                      Drill and Tap it (1/4") no big deal, 1/2" X 1/4" bsp compression coupling (plumbing fitting) in the top then a little K&N filter on top job done.
                      [IMG][/IMG]
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Just what i was thinking i have plans :mischeif: thanks jon i owe you one
                        Chef
