ECU Loom
  • sal_s2
    • 1287
    I'm currently installing an aby loom into my 1989 ur quattro. Would the above apply to me also?
    I also have the green wires and a couple of red ones spare, are the fuse boxes the same?
    • ~Delta
      • Apr 2005
      • 797
      Sal, Ur quattro fuse box is the same.
      Never show a fool a half built house.
      Never underestimate the power of stupid people in large groups.
      Life is like a **** sandwich
      The more bread you have, the less **** you eat
      • sal_s2
        • 1287
        Did anyone suss out where the single red spade goes on the fusebox? From the size it looks as though it should connect to a permanent live feed
        Theres also a red plug with a green wire and a yellow wire that I dont what its for? Anyone know?
        • sal_s2
          • 1287
          Can I just earth these 2 wires on fuse box ( the gold connector thing in the pic)? What are they for?
          • sal_s2
            • 1287
            Also is this block for the centre console gauges, i.e oil pressure and temp?
            • ~Delta
              • Apr 2005
              • 797
              #21
              Large spade is permanent live (term. 30)
              Ring terminals in the second picture are earthed by the fusebox. Diagnostic feed.
              Ignore the red plug in a type 85 chassis.
              Black plug in third picture is for your dash instruments - water temp, brake fluid warning (grey / yellow) coolant level, alternator and a few others. Give me the colours, and I'll tell you what they are. Been some time since I fitted an S2 engine to a type 85 chassis.
              • sal_s2
                • 1287
                Nice one delta, I'll let you know what colour the spare wires from the urq loom are aswell. There are about 2 single wires from the aby loom left over and also the plug that jon posted a pic of in the first post.
                Not sure what to do about the alternator loom. Was going to remove it from an s2 as its seperate to the aby engine loom and fit it into the ur or is there an easier way? I'm leaving the alternator on the passenger side whereas its normally fitted to the drivers side on the ur and the wiring to it is part of the ur engine loom.
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Sal where did you earth the diagnostic wires to? My fuse box has no small bolts on the side to do this with
                  Chef
