differance in motors
  • andy112
    • Nov 2006
    • 133
    • Home: Poland Current: Canada
    Hey what is the difference between the s2 motor vs urs4/s6 motors? I know that the intake is on the opposite side right? Also will the heads from the s2 fit the s4 motor, and which one is stronger? The reason Im asking is because I have a 90 CQ and I want to do a turbo swap in it and want to find a cheap route to swap and I think that a full s2 motor would cost alot.
  • Billman
    • 4129
    The S2-ABY head and the UrS4/S6 - AAN head are the same.
    Go Holset or Go RS4
    • andy112
      • Nov 2006
      • 133
      meaning that I can put the s2 head on the s4 block? What about the block is one stronger then the other? Also is there a huge differance in the two motors, which would be better to swap into a 90 CQ?
      Edit: Also by differance I mean strength too for example the supra has an iron block and the na doesnt. Also what about my stock 20v na motor would I be able to turbo that Ive seen a guy rebuild and turbo a 7a block and heads, would this be as reliable and make the power and be equivalent to a s4 or s2 swap?
        Andy: Where are you in Canada? There are people across Canada that have swapped in 3B and AAN 20v turbo engines into coupe quattros produce something close to the S2 (which was never imported into Canada).
        Dave F. (with an UrS4) in Vancouver
        • DJones
          • Jun 2005
          • 2020
          I have heard it said that the AAN is a better engine.... Personally i think they are identical (AAN/ABY) apart from inlet tract.
          • andy112
            • Nov 2006
            • 133
            I am by Toronto. Do you know how much a s4/s6 motor and 6 speed goes for at a scrap yard?
            whats different about the inlet tract? Also the AAN motor being the s4/s6 motor right,
            • aronmatic2
              • 2129
              • Country: Hungary
              i lived in mississauga for 5 years.
              bough beeches blvd.
              you was my neighbour
              Real carbon parts for S2 and RS2. Check Carbondesign on facebook
                A complete UrS4 (1992-94) parts car with engine will go for about $3000 to $4000. AANs alone are usually in the $2500 range, if you can find one. There were no 6 spd UrS cars in North America. We have been upgrading to CBR 6 spds from RS2s (also NOT imported to North America) or B5 S4 tt (EDU or DSY).
                The AAN has the throttle body near the front of the engine (there is more room because the engine bay is longer in the C4 body than the B3/B4 shells). The 3B, ABY and ADU engines all had the throttle body at the rear of the intake manifold.
                I will contact you with Personal Mail to get your email address so I can connect you to a couple of guys in Ontario that I know are doing this conversion. There is also R33girl in Ottawa who has done a conversion.
                Dave F.
                • andy112
                  • Nov 2006
                  • 133
                  awesome so anyone know how much a 3b motor goes for? Also while using a 2.7TT 6 speed what other parts do you need, like mounts, half shafts, differential, etc.?
                  • prosty
                    • Jun 2005
                    • 1114
                    The engines are "basically" the same except for the intake and intercooler solution, I think everything is pretty much bolt-on with the exception of some "home made" fittings here and there, no bigger issues anyway. And the trannies for S4 TT fits without hassle
                    2004 9-5 aero
                    2009 Subaru Legacy Diesel
                    1994 Toyota Supra Eurospec 6-spd LHD
                    3-4 Audis in parts
                    • andy112
                      • Nov 2006
                      • 133
                      So after talking to a few people they say to go 3b or aan with 3b intake. Is the intake on the aan the only limiting factor or the only thing preventing an easy swap? The people I talked to said that if I went aan I would have to move PS, rad and lines and ac so if I went aan with 3b intake would I avoid all these issues??
                      • couperman
                        • Nov 2005
                        • 62
                        I went with the AAN motor because it was easier to locate stateside. Incidentally you can put a 3b intake manifold on the aan, and the PS pump. The only issue is the throttle body will rub against the head of the motor, so you'll need a phenolic spacer. Here's a link to check them out. $160 usd shipped.
                        hope it helps
                        AAN 20vt conversion
                        Boosting 29 psi!
                        • couperman
                          • Nov 2005
                          • 62
                          sorry for the broken english in that last post. The 3b intake manifold on the AAN works great and has no effect on the PS! The spacer helps clear the 3B intake from the head..
                          AAN 20vt conversion
                          Boosting 29 psi!
