Disaster!!!!!
  • blown_vr6
    • Apr 2005
    • 406
    Glad my Avant has a brand new crank pulley,cambelt and all associated bits.
    Hope it doesnt turn out too bad Phil.
    Pete.
    'If you ain't broke it you ain't trying hard enough'
    Oh sh*t i broke it
    94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
    • phil2.016v
      • Mar 2006
      • 300
      Pete.
      Cheers Pete, I bought a new crank sprocket ages ago but never fitted it, I think I might get away with replacing that with a new main pulley and a vibration damper. I think that might be the cause of the problem!
      Audi 80 2.0
      E21 BMW 316
      Ibiza Cupra Sport
      Mk3 Golf GTI colour Concept in black!
      Mk3 Golf GTI
      VW Caddy van with my gottis on it
      • Keeper of The Kitten
        • Dec 2003
        • 2317
        Jeez Phil that's rough luck!
        Fingers crossed for a minimal repair bill.
        __MDC__
        Martin Cutting
        • sal_s2
          • 1288
          Happened to Jamil in his shorty, result was 10 bent valves and guides.
            #20
            God I wish our engines were non-interference... Then a failure like that is just annoying / embarrassing / hard to get home - without none of the bank account surgery and stress of such a head rebuild.
            Paul
            • phil2.016v
              • Mar 2006
              • 300
              #21
              Paul
              Tell me about it!! It looks like the ECU mod will have to wait a bit longer Paul!
              Audi 80 2.0
              E21 BMW 316
              Ibiza Cupra Sport
              Mk3 Golf GTI
              • Ross
                • Aug 2005
                • 3399
                Sorry to hear this, hope damage is minimal... just ask santa for some new parts he won't think you're a greedy c*nt - I asked for a whole new car
                • Crawford_S2
                  • 1555
                  #23
                  Not going to give up on the old one are you bro, get it in the garage! Winter is the best time for a reshell anyway
                  Ragusa Coupe gone!
                  • volcano rs
                    • Jun 2005
                    • 2265
                    sorry to hear this you will have deffinetly bent most if not all inlet valves and depending on how fast you was revving the engine 'probably pistons too and few valve guides . its same effect as snapping your timing belt.
                    i'm thinking of having the sprocket made in hardened steel with a seperate woodruff key. standard is made out of cast and is too weak' mine snapped in 3 places .
                    • S-Express
                      • Nov 2006
                      • 1133
                      #25
                      I don't understand why the woodruff key is being blamed so much.
                      It is only there to locate the pulley - once the pulley bolt is tightened to the required torque then the key is not being used as a locking device.
                      I've just done the cambelt on my ABY and the key has a crack half way through it. IMO the key is actually getting damaged when the pulley is being tightened/loosened as this is the time when it is going through the most stress - once that bolt is tight, the key's job is done and dusted. BUT it shouldn't matter how damaged the key is once everthing is done up tight. The pulley is definitely a poor quality item - I think it may even be sintered??? rather than cast which makes it even weaker.
                      For what its worth, I run a tuned 2.0 zetec in another car, and zetec cam wheels have no keys at all! The cam wheel is bolted to the cam and the secureness of the two cpomponents is purely down to the bolt torque and therefore friction between the 2 faces.
                      It sounds to me like (possibly) when Phil's head was put back on after the head gasket trouble, that the bottom pulley was not done up to the required torque???
                      Just my 2 penneth - oh and Phil - it was me who was gonna but your Avant but it was in the garage with knackered slave cylinder when I cam to view!!!
                      • Graham
                        • 1622
                        #26
                        I Agree, but the design does not alow any room for idiot proofness, and the whole top end and PAS pump, air con, alternator is all driven by the head of that wee bolt on the crank, i think it is crap, i dont think the crank end is a hard material either, as mine was feathered when the bolt came out of mine after the garage botched mine a few years ago, mine was doing 70-80 slowing down into a round about in 6th and it bent all 10 inlet, so new guides, valves, a pressure test, along with new seals, gasket and piston polish saw me right, but this cost about a Grand in bits and i re-done the work to AAn workshop manual.
                        • phil2.016v
                          • Mar 2006
                          • 300
                          #27
                          It's more likely the vibration damper that's at fault, a common problem which I should have sorted!!! It shows itself as a wobbly main pulley so take note peeps!
                          I towed the car over to my mate's place yesterday so I'll let you know what the damage is! At least I'll have an A1 Avant by the time its finished
                          Audi 80 2.0
                          E21 BMW 316
                          Ibiza Cupra Sport
                          Mk3 Golf GTI
                          • S-Express
                            • Nov 2006
                            • 1133
                            #28
                            Hmmm, this vibration damper. Where is it?
                            I've just done the cambelt and associated bits and bobs on my 94 ABY and didn't see anything that looked remotely like a vibration damper?
                            Maybe I was looking with my feet - I often get accused of that.
                            • phil2.016v
                              • Mar 2006
                              • 300
                              #29
                              I don't know yet! I know they are about 270 quid though. I'll spill the beans when I find out, or I'm sure someone will tell us!
                              Audi 80 2.0
                              E21 BMW 316
                              Ibiza Cupra Sport
                              Mk3 Golf GTI
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #30
                                The vibration damper also drives the PAS pump, A/C compressor and alternator.
                                SS
