Just Finnished putting my 3B back together, Things that ive changed are :- 7A Cams, RS2 turbo withn standard 3b manifold (can't afford yet) and removed air con.
When i try to start it the starter turns the engine but there is no spark. There is fuel just before the injecters but probably not being injected! Before i take it to get fault codes does anyone have any ideas. ie does removing air con effect the engine starting. i have checked engine fuses.
