running lean -- plan of action?
  • Chris5044
    • Feb 2005
    • 1663
    hi guys ... been busy lately ... I found out that my s2 runs lean fuel and pushes 260hp with 320 ftlbs
    I had this dynoed recently ...
    the car was chipped in 1997 by amd .. any idea on how to fix the lean running?
    the fuel filter was changed before dyno too....
    Ive been told to get a remap ... but i dont wanna fork out loads of money to find that it doesnt fix the problem
    is there a specialist i can see?
  • Chris M
    • Sep 2003
    • 1030
    The problem is the map/chip itself, it runs lean up the top end!
    Solution, get a MRC remap or a generic chip from MRC or Mr Nugent
    Cheers,
    Chris
    Silver S2 Avant : Sold
    • dan_b
      • Sep 2003
      • 3670
      LOL. I thought that chips on the S2 gave a tendency to run a bit rich - apparently the extra un-burnt fuel in the exhaust is used as a means to keep EGTs down?
      • Chris M
        • Sep 2003
        • 1030
        Or the more fuel in the engine during combustion keeps the temps down
        Cheers,
        Chris
        • quattro
          • Dec 2004
          • 768
          Funny that i have an AmD remap and my S2 allso runs lean (glowing turbo, manifold & downpipe) when i give her some stick for a bit!
          Probably the longet S2 project in history EVER!
          • Chris5044
            • Feb 2005
            • 1663
            surely it would have shown up on the previous dyno runs? (the lean running).. (i have them too)
            ... what leaks would i need to look for - if any, that might cause lean running? is this a possibility? .. ive no idea
            • Azman
              • Sep 2005
              • 3205
              I have got the same prob at the mo so I am taking abit of time over this and have taken the car off the road so I can check and double cheeck everything!! All points towards the chip/remapp though!! once done MRC here we come!
              Dark Grey Avant
              RS2 FARB
              Alloy Subframe Bushes
              • Chris5044
                • Feb 2005
                • 1663
                can you keep us posted on what u find.... i cant do much atm .. with lack of funds (student )
                • Chris5044
                  • Feb 2005
                  • 1663
                  bump .....
                  would a boost leak cause lean running? or hesitence at high speed?
                  or is there such thing as a build up of crap in the fuel system leading to me stripping and blasting with a compressor? + fuel pump too?
                  ideas?
                    You can have your injectors cleaned up, and also replace your fuel pump for a bosch motorsport. But your putting band aids on a cut artery mate.
                    If i was you buy a home fry chip or have it remapped at MRC.
                    Was it lean only at top rpm or through out the range?
                    • prosty
                      • Jun 2005
                      • 1114
                      Get bigger injetors or raise the fuel pressure if you don't want to pay for a remap.
                      But you're still risking your engine. I would say, better to pay for a new map than a new set of rods and pistons..
                      /Markus
                      2004 9-5 aero
                      2009 Subaru Legacy Diesel
                      1994 Toyota Supra Eurospec 6-spd LHD
                      3-4 Audis in parts
                        Just realised you have a 3B so you can't buy a home fries chip.
                        Changing the FPR as prosty says to an ABY or 7A one which will raise fuel pressure to 4bar. Depends though this may make you too rich.
                        • Azman
                          • Sep 2005
                          • 3205
                          Chriss After mucho hunting, stripping and playing there is nothing I have found other than a few grazed knuckles and the need for a new dizzy cap and arm. Changing the HT leads too for good measure mind. (Okay okay I am doing lots of other work whislt I am here but a remapp is the way forward!!)
                          Jamo what pressure does the AAN FPR run at?
                          Dark Grey Avant
                          RS2 FARB
                          • prosty
                            • Jun 2005
                            • 1114
                            Jamo yepp 4 bar is 30% more fuel which is a lot .
                            2004 9-5 aero
                            3-4 Audis in parts
                              @ Azman
                              The AAN and ABY are both 4 bar
