ref's whistle
  • peter
    • Dec 2004
    • 96
    ref's whistle
    i can't describe it as anything else,under mid/high boost i get a sound similar to a ref's whistle.with the passenger window open you can really here it,the car is running fine and is definately not running lean (checked with wideband sensor),no boost leaks either.sound dies off as revs/boost settle at high rpm.turbo is new,did the same with the old one but did not always make this sound.any ideas?
  • s2dude
    • Nov 2005
    • 1631
    Sounds like it may be Full Time?
    • s2dude
      • Nov 2005
      • 1631
      Sorry...bad joke
      Being serious.
      have you replaced the recirc dump valve??
        Red card for S2dude
        Sounds like your exhaust manifold maybe cracked mate.
        • s2dude
          • Nov 2005
          • 1631
          Originally posted by Jamo
          Red card for Andy
          • peter
            • Dec 2004
            • 96
            sounds like no turkey for me this christmas!i have got an s3 dv i am going to fit,i cant here any noise from the manifold when revving up/head under bonnet am just concerned it sounds a bit like pinking but it is too constant and the mixture is spot on.
            i will try the dv first and let you know
